Radix conversion for IEEE754-2008 mixed radix floating-point arithmetic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Conversion between binary and decimal floating-point representations is ubiquitous. Floating-point radix conversion means converting both the exponent and the mantissa. We develop an atomic operation for FP radix conversion with simple straight-line algorithm, suitable for hardware design. Exponent conversion is performed with a small multiplication and a lookup table. It yields the correct result without error. Mantissa conversion uses a few multiplications and a small lookup table that is shared amongst all types of conversions. The accuracy changes by adjusting the computing precision.
radixConversion.pdf (257.81 Ko) Télécharger le fichier
hal-01513505 , version 1 (25-04-2017)
Olga Kupriianova, Christoph Lauter, Jean-Michel Muller. Radix conversion for IEEE754-2008 mixed radix floating-point arithmetic. 2013 Asilomar Conference on Signals, Systems and Computers , Nov 2013, Pacific Grove, CA, United States. pp.1134 - 1138, ⟨10.1109/ACSSC.2013.6810471⟩. ⟨hal-01513505⟩
275 Consultations
225 Téléchargements
