On the maximum relative error when computing integer powers by iterated multiplications in floating-point arithmetic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerical Algorithms Année : 2015
Vincent Lefèvre
Jean-Michel Muller
We improve the usual relative error bound for the computation of x^n through iterated multiplications by x in binary floating-point arithmetic. The obtained error bound is only slightly better than the usual one, but it is simpler. We also discuss the more general problem of computing the product of n terms.
Autre [cs.OH]
x-puissance-n-revision.pdf (482.17 Ko) Télécharger le fichier
ensl-00945033 , version 1 (11-02-2014)
ensl-00945033 , version 2 (17-10-2014)
Stef Graillat, Vincent Lefèvre, Jean-Michel Muller. On the maximum relative error when computing integer powers by iterated multiplications in floating-point arithmetic. Numerical Algorithms, 2015, 70 (3), pp.653-667. ⟨10.1007/s11075-015-9967-8⟩. ⟨ensl-00945033v2⟩
535 Consultations
575 Téléchargements
