On the Toppling of a Sand Pile - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2001
In this paper, we provide the first study of the sand pile model SPM(0) where we assume that all the grains are numbered with a distinct integer.We obtain a lower bound on the number of terminal sand piles by establishing a bijection between a subset of these sand piles and the set of shifted Young tableaux. We then prove that this number is at least factorial.
dmAA0120.pdf (87.05 Ko) Télécharger le fichier
hal-01182963 , version 1 (06-08-2015)
Jean-Christophe Novelli, Dominique Rossin. On the Toppling of a Sand Pile. Discrete Models: Combinatorics, Computation, and Geometry, DM-CCG 2001, 2001, Paris, France. pp.275-286, ⟨10.46298/dmtcs.2283⟩. ⟨hal-01182963⟩
262 Consultations
739 Téléchargements
