Generic properties of singular trajectories - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Comptes rendus de l'Académie des sciences. Série I, Mathématique Année : 2003
Yacine Chitour
Frédéric Jean
We give genericity results for singular trajectories in sub-Riemannian geometry: generically (in the sense of the Whitney topology), every singular trajectory is of minimal order and of corank 1 and in particular is not of Goh type if the rank of the distribution is greater or equal to 3. We extend these results to control-affine systems.
cras.pdf (76.31 Ko) Télécharger le fichier
hal-00086321 , version 1 (18-07-2006)
  • HAL Id : hal-00086321 , version 1
Yacine Chitour, Frédéric Jean, Emmanuel Trélat. Generic properties of singular trajectories. Comptes rendus de l'Académie des sciences. Série I, Mathématique, 2003, 337 (1), pp.49--52. ⟨hal-00086321⟩
91 Consultations
138 Téléchargements
