Genericity results for singular curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Differential Geometry Année : 2006
Yacine Chitour
Frédéric Jean
Let $M$ be a smooth manifold and ${\cal D}_m$, $m\geq 2$, be the set of rank $m$ distributions on $M$ endowed with the Whitney $C^\infty$ topology. We show the existence of an open set $O_m$ dense in ${\cal D}_m$, so that, every nontrivial singular curve of a distribution $D$ of $O_m$ is of minimal order and of corank one. In particular, for $m\geq 3$, every distribution of $O_m$ does not admit nontrivial rigid curves. As a consequence, for generic sub-Riemannian structures of rank greater than or equal to three, there does not exist nontrivial minimizing singular curves.
CJT.pdf (263.32 Ko) Télécharger le fichier
hal-00086357 , version 1 (18-07-2006)
Yacine Chitour, Frédéric Jean, Emmanuel Trélat. Genericity results for singular curves. Journal of Differential Geometry, 2006, 73 (1), pp.45-73. ⟨10.4310/jdg/1146680512⟩. ⟨hal-00086357⟩
135 Consultations
147 Téléchargements
