Chemical and Photometric Evolution of Extended Ultraviolet Disks: Optical Spectroscopy of M83 (NGC5236) and NGC4625 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2007
David Thilker
Tim Conrow
  • Fonction : Auteur
Susan Gale Neff
  • Fonction : Auteur
Robert Michael Rich
  • Fonction : Auteur
David Schiminovich
  • Fonction : Auteur
Mark Seibert
  • Fonction : Auteur
Todd Small
  • Fonction : Auteur
Alex Szalay
  • Fonction : Auteur
Ted Wyder
  • Fonction : Auteur
Sukyoung Yi
We present the results from the analysis of optical spectra of 31 Halpha-selected regions in the extended UV (XUV) disks of M83 (NGC5236) and NGC4625 recently discovered by GALEX. The spectra were obtained using IMACS at Las Campanas Observatory 6.5m Magellan I telescope and COSMIC at the Palomar 200-inch telescope, respectively for M83 and NGC4625. The line ratios measured indicate nebular oxygen abundances (derived from the R23 parameter) of the order of Zsun/5-Zsun/10. For most emission-line regions analyzed the line fluxes and ratios measured are best reproduced by models of photoionization by single stars with masses in the range 20-40 Msun and oxygen abundances comparable to those derived from the R23 parameter. We find indications for a relatively high N/O abundance ratio in the XUV disk of M83. Although the metallicities derived imply that these are not the first stars formed in the XUV disks, such a level of enrichment could be reached in young spiral disks only 1 Gyr after these first stars would have formed. The amount of gas in the XUV disks allow maintaining the current level of star formation for at least a few Gyr.
hal-00131501 , version 1 (16-02-2007)
Armando Gil de Paz, Barry Madore, Samuel Boissier, David Thilker, Luciana Bianchi, et al.. Chemical and Photometric Evolution of Extended Ultraviolet Disks: Optical Spectroscopy of M83 (NGC5236) and NGC4625. 2007. ⟨hal-00131501⟩
190 Consultations
0 Téléchargements
