PARDI ! - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
PARDI !
We propose a new algorithm for converting a characteristic set of a prime differential ideal from one ranking into another. This differential algebra algorithm computes characteristic sets by change of ranking (ordering) for prime ideals. It identifies the purely algebraic subproblems which arise during differential computations and solves them algebraically. There are two improvements w.r.t. other approaches: formerly unsolved problems could be carried out; it is conceptually simple. Different variants are implemented.
BLM01.pdf (175.58 Ko) Télécharger le fichier
hal-00139354 , version 1 (30-03-2007)
François Boulier, François Lemaire, Marc Moreno Maza. PARDI !. international symposium on Symbolic and algebraic computation 2001, 2001, France. pp.38-47, ⟨10.1145/384101.384108⟩. ⟨hal-00139354⟩
634 Consultations
127 Téléchargements
