Efficient computation of regular differential systems by change of rankings using Kähler differentials
We present two algorithms to compute a regular differential system for some ranking, given an equivalent regular differential system for another ranking. Both make use of Kähler differentials. One of them is a lifting for differential algebra of the FGLM algorithm and relies on normal forms computations of differential polynomials and of Kähler differentials modulo differential relations. Both are implemented in MAPLE V. A straightforward adaptation of FGLM for systems of linear PDE is presented too. Examples are treated.
