A reduced-order strategy for 4D-Var data assimilation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Marine Systems Année : 2005
This paper presents a reduced-order approach for four-dimensional variational data assimilation, based on a prior EO F analysis of a model trajectory. This method implies two main advantages: a natural model-based definition of a mul tivariate background error covariance matrix $\textbf{B}_r$, and an important decrease of the computational burden o f the method, due to the drastic reduction of the dimension of the control space. % An illustration of the feasibility and the effectiveness of this method is given in the academic framework of twin experiments for a model of the equatorial Pacific ocean. It is shown that the multivariate aspect of $\textbf{B}_r$ brings additional information which substantially improves the identification procedure. Moreover the computational cost can be decreased by one order of magnitude with regard to the full-space 4D-Var method.
revis.pdf (1.96 Mo) Télécharger le fichier
hal-00172943 , version 1 (18-09-2007)
Céline Robert, Sophie Durbiano, Eric Blayo, Jacques Verron, Jacques Blum, et al.. A reduced-order strategy for 4D-Var data assimilation. Journal of Marine Systems, 2005, 57 (1-2), pp.70-82. ⟨10.1016/j.jmarsys.2005.04.003⟩. ⟨hal-00172943⟩
696 Consultations
204 Téléchargements
