s'authentifier
version française rss feed
hal-00180769, version 1
High pressure behavior of CsC8 graphite intercalation compound
N. Rey 1, Pierre Toulemonde 12, D. Machon 1, L. Duclaux 3, S. Le Floch 1, V. Pischedda 1, J.P. Itié 4, A.-M. Flank 4, P. Lagarde 4, W.A. Chrichton 5, M. Mezouar 5, T. Strässle 6, D. Sheptyakov 6, Gilles Montagnac 7, A. San-Miguel 1
Physical Review B 77, 12 (2008) 125433
Résumé : The high pressure phase diagram of CsC8 graphite intercalated compound has been investigated at ambient temperature up to 32 GPa. Combining X-ray and neutron diffraction, Raman and X- ray absorption spectroscopies, we report for the first time that CsC8, when pressurized, undergoes phase transitions around 2.0, 4.8 and 8 GPa. Possible candidate lattice structures and the transition mechanism involved are proposed. We show that the observed transitions involve the structural re- arrangement in the Cs sub-network while the distance between the graphitic layers is continuously reduced at least up to 8.9 GPa. Around 8 GPa, important modifications of signatures of the electronic structure measured by Raman and X-ray absorption spectroscopies evidence the onset of a new transition.
  • Domaine : Physique/Matière Condensée/Science des matériaux
  • Mots-clés : graphite interclation compounds – pressure – structural transitions
  • hal-00180769, version 1
  • oai:hal.archives-ouvertes.fr:hal-00180769
  • Contributeur :
  • Soumis le : Mercredi 24 Octobre 2007, 17:16:02
  • Dernière modification le : Mardi 2 Octobre 2012, 15:24:57
tous les articles de la base du CCSd...
