Unknown input observers for switched nonlinear discrete time descriptor systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2008
In this paper, a linear matrix inequality (LMI) technique for state estimation of discrete-time, nonlinear switched descriptor systems is developed. The considered systems are composed of linear and nonlinear parts. An observer giving a perfect unknown input (UI) decoupled state estimation is proposed. Sufficient conditions of global convergence of observers are proposed. Numerical examples are given to illustrate this method.
2008_IEEE_TAC.pdf (126.91 Ko) Télécharger le fichier
hal-00193514 , version 1 (25-11-2021)
Damien Koenig, Benoît Marx, Denis Jacquet. Unknown input observers for switched nonlinear discrete time descriptor systems. IEEE Transactions on Automatic Control, 2008, 53 (1), pp.373-379. ⟨10.1109/TAC.2007.914226⟩. ⟨hal-00193514⟩
311 Consultations
72 Téléchargements
