A Distributed WCET Computation Scheme for Smart Card Operating Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
Computing WCET in a resource-constrained device such as a smart card in a safe manner raises some difficulties. In- deed, most of the classical algorithms for computing WCET do not address resource-limitation or security issues. In this article, we propose to distribute the computation process between the off-card part running on a powerful workstation and the on-card part specific to the hardware included in the smart card. We also guarantee the safety of our com- putation process by inserting assertions in the generated code and preventing information leaks from the card to the outside.
04-Aissa-WCET.pdf (91.56 Ko) Télécharger le fichier
hal-00309686 , version 1 (07-08-2008)
  • HAL Id : hal-00309686 , version 1
Nadia Bel Hadj Aissa, Christophe Rippert, Damien Deville, Gilles Grimaud. A Distributed WCET Computation Scheme for Smart Card Operating Systems. 4th International Workshop on Worst-Case Execution Time Analysis, in association with the 16th Euromicro ECRTS conference, Jun 2004, Catania, Italy. ⟨hal-00309686⟩
694 Consultations
144 Téléchargements
