Synchronizing Behavioural Mismatch in Software Composition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Software Adaptation is a crucial issue for the development of a real market of components promoting software reuse. Recent work in this field has addressed several problems related to interface and behavioural mismatch. In this paper, we present our proposal for software adaptation, which builds on previous work overcoming some of its limitations, and makes a significant advance to solve pending issues. Our approach is based on the use of synchronous vectors and regular expressions for governing adaptation rules, and is supported by dedicated algorithms and tools.
fmood2006.pdf (402.12 Ko) Télécharger le fichier
hal-00342017 , version 1 (15-04-2014)
Carlos Canal, Pascal Poizat, Gwen Salaün. Synchronizing Behavioural Mismatch in Software Composition. Proceedings of the 8th International Conference on Formal Methods for Open Object-Based Distributed Systems (FMOODS), Jun 2006, Bologna, Italy. pp.63--77, ⟨10.1007/11768869_7⟩. ⟨hal-00342017⟩
193 Consultations
182 Téléchargements
