A Formal Architectural Description Language based on Symbolic Transition Systems and Modal Logic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Universal Computer Science Année : 2006
Component Based Software Engineering has now emerged as a discipline for system development. After years of battle between component platforms, the need for means to abstract away from specific implementation details is now recognized. This paves the way for model driven approaches (such as MDE) but also for the more older Architectural Description Language (ADL) paradigm. In this paper we present KADL, an ADL based on the Korrigan formal language which supports the following features: integration of fully formal behaviours and data types, expressive component composition mechanisms through the use of modal logic, specification readability through graphical notations, and dedicated architectural analysis techniques. Key Words: Architectural Description Language, Component Based Software Engineering, Mixed Formal Specifications, Symbolic Transition Systems, Abstract Data Types, Modal Logic Glue, Graphical Notations, Verification.
jucs_12_12_1741_1782_poizat.pdf (332.25 Ko) Télécharger le fichier
hal-00342156 , version 1 (02-02-2016)
Pascal Poizat, Jean-Claude Royer. A Formal Architectural Description Language based on Symbolic Transition Systems and Modal Logic. Journal of Universal Computer Science, 2006, 12 (12), pp.1741-1782. ⟨10.3217/jucs-012-12-1741⟩. ⟨hal-00342156⟩
295 Consultations
371 Téléchargements
