Identification of equivalent topography in an open channel flow using Lagrangian data assimilation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computing and Visualization in Science Année : 2010
We present a Lagrangian data assimilation experiment in an open channel flow above a broad-crested weir. The observations consist of trajectories of particles transported by the flow and extracted from a video film, in addition to classical water level measurements. However, the presence of vertical recirculations on both sides of the weir actually conducts to the identification of an equivalent topography corresponding to the lower limit of a surface jet. In addition, results on the identification of the Manning coefficient may allow to detect the presence of bottom recirculations.
HonnoratMonnierRiviereEtAL08.pdf (232.62 Ko) Télécharger le fichier
hal-00380703 , version 1 (04-05-2009)
Marc Honnorat, Jerome Monnier, Nicolas Riviere, Etienne Huot, François-Xavier Le Dimet. Identification of equivalent topography in an open channel flow using Lagrangian data assimilation. Computing and Visualization in Science, 2010, 13 (3), pp.111-119. ⟨10.1007/s00791-009-0130-8⟩. ⟨hal-00380703⟩
648 Consultations
313 Téléchargements
