Guaranteed delivery for geographical anycasting in wireless multi-sink sensor and sensor-actor networks.
In the anycasting problem, a sensor wants to report event information to one of sinks or actors. We describe the first localized anycasting algorithms that guarantee delivery for connected multi-sink sensor-actor networks. Let $S(x)$ be the closest actor/sink to sensor $x$, and $|xS(x)|$ be distance between them. In greedy phase, a node $s$ forwards the packet to its neighbor $v$ that minimizes the ratio of cost $cost(|sv|)$ of sending packet to $v$ (here we specifically apply hop-count and power consumption metrics) over the reduction in distance ($|sS(s)|-|vS(v)|$) to the closest actor/sink. A variant is to forward to the first neighbor on the shortest weighted path toward $v$. If none of neighbors reduces that distance then recovery mode is invoked. It is done by face traversal toward the nearest connected actor/sink, where edges are replaced by paths optimizing given cost. A hop count based and two variants of localized power aware anycasting algorithms are described. We prove guaranteed delivery property analytically and experimentally.
