Encapsulation and Dynamic Modularity in the Pi-Calculus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
We describe a process calculus featuring high level constructs for component-oriented programming in a distributed setting. We propose an extension of the higher-order pi-calculus intended to capture several important mechanisms related to component-based programming, such as dynamic update, reconfiguration and code migration. In this paper, we are primarily concerned with the possibility to build a distributed implementation of our calculus. Accordingly, we define a low-level calculus, that describes how the high-level constructs are implemented, as well as details of the data structures manipulated at runtime. We also discuss current and future directions of research in relation to our analysis of component-based programming.
edmpc.pdf (207.42 Ko) Télécharger le fichier
hal-00400159 , version 1 (30-06-2009)
Daniel Hirschkoff, Aurélien Pardon, Tom Hirschowitz, Samuel Hym, Damien Pous. Encapsulation and Dynamic Modularity in the Pi-Calculus. PLACES 2008, 2008, Oslo, Norway. pp.85 - 100, ⟨10.1016/j.entcs.2009.06.005⟩. ⟨hal-00400159⟩
261 Consultations
188 Téléchargements
