Influence of Gauss and Gauss-Lobatto quadrature rules on the accuracy of a quadrilateral finite element method in the time domain. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerical Methods for Partial Differential Equations Année : 2009
In this paper, we examine the infl uence of numerical integration on finite element methods using quadrilateral or hexahedral meshes in the time domain. We pay special attention to the use of Gauss-Lobatto points to perform mass lumping for any element order. We provide some theoretical results through several error estimates that are completed by various numerical experiments.
DurufleGrobJoly.pdf (375.29 Ko) Télécharger le fichier
hal-00403791 , version 1 (13-07-2009)
Marc Duruflé, Pascal Grob, Patrick Joly. Influence of Gauss and Gauss-Lobatto quadrature rules on the accuracy of a quadrilateral finite element method in the time domain.. Numerical Methods for Partial Differential Equations, 2009, 25 (3), pp.526-551. ⟨10.1002/num.20353⟩. ⟨hal-00403791⟩
483 Consultations
2509 Téléchargements
