Rule-based modeling of transcriptional attenuation at the tryptophan operon - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Transactions on Computational Systems Biology Année : 2010
Transcriptional attenuation at E.coli's tryptophan operon is a prime example of RNA-mediated gene regulation. In this paper, we present a discrete stochastic model of the fine-grained control of attenuation, based on chemical reactions. Stochastic simulation of our model confirms results that were previously obtained by master or differential equations. Our approach is easier to understand than master equations, although mathematically well founded. It is compact due to rule schemas that define finite sets of chemical reactions. Object-centered languages based on the pi-calculus would yield less intelligible models. Such languages are confined to binary interactions, whereas our model heavily relies on reaction rules with more than two reactants, in order to concisely capture the control of attenuation.
tcsb.pdf (682.4 Ko) Télécharger le fichier
hal-00445566 , version 1 (09-01-2010)
  • HAL Id : hal-00445566 , version 1
Celine Kuttler, Cédric Lhoussaine, Mirabelle Nebut. Rule-based modeling of transcriptional attenuation at the tryptophan operon. Transactions on Computational Systems Biology, 2010, XII, pp.199-228. ⟨hal-00445566⟩
216 Consultations
248 Téléchargements
