hal-00448441, version 1
Size of the medial axis and stability of Federer's curvature measures
(18/01/2010)
Résumé : In this article, we study the (d-1)-volume and the covering numbers of the medial axis of a compact set of the Euclidean d-space. In general, this volume is infinite; however, the (d-1)-volume and covering numbers of a filtered medial axis (the mu-medial axis) that is at distance greater than R from the compact set will be explicitely bounded. The behaviour of the bound we obtain with respect to mu, R and the covering numbers of the compact set K are optimal. From this result we deduce that the projection function on a compact subset K of the Euclidean d-space depends continuously on the compact set K, in the L^1 sense. This implies in particular that Federer's curvature measure of a compact set with positive reach can be reliably estimated from a Hausdorff approximation of this set, regardless of any regularity assumption on the approximation.
- Domaine : Mathématiques/Géométrie métrique
- Mots-clés : curvature measures – projection function – medial axis – cut locus – distance function
- Commentaire : 15 pages – 2 figures
- hal-00448441, version 1
- http://hal.archives-ouvertes.fr/hal-00448441
- oai:hal.archives-ouvertes.fr:hal-00448441
- Contributeur : Quentin Mérigot
- Soumis le : Mardi 19 Janvier 2010, 02:41:15
- Dernière modification le : Mardi 19 Janvier 2010, 02:41:15
Documents associés
Exporter
