s'authentifier
version française rss feed
hal-00460558, version 3
Fast orthogonal sparse approximation algorithms over local dictionaries
Boris Mailhé () 1, Rémi Gribonval () 1, Pierre Vandergheynst () 2, Frédéric Bimbot () 1
Signal Processing (2011)
Résumé : In this work we present a new greedy algorithm for sparse approximation called LocOMP. LocOMP is meant to be run on local dictionaries made of atoms with much shorter supports than the signal length. This notably encompasses shift-invariant dictionaries and time-frequency dictionaries, be they monoscale or multiscale. In this case, very fast implementations of Matching Pursuit are already available. LocOMP is almost as fast as Matching Pursuit while approaching the signal almost as well as the much slower Orthogonal Matching Pursuit.
  • 1 :  METISS (INRIA - IRISA)
  • CNRS : UMR6074 – INRIA – INSA Rennes – Université de Rennes 1
  • 2 :  LTS2 - EPFL
  • École Polytechnique Fédérale de Lausanne
  • Domaine : Sciences de l'ingénieur/Traitement du signal et de l'image
    Informatique/Traitement du signal et de l'image
  • Mots-clés : sparse approximation – greedy algorithms – shift invariance – Orthogonal Matching Pursuit
  • Référence interne : RR-7483
  • Versions disponibles :  v1 (01-03-2010) v2 (15-12-2010) v3 (26-04-2011)
  • hal-00460558, version 3
  • oai:hal.inria.fr:hal-00460558
  • Contributeur :
  • Soumis le : Mardi 26 Avril 2011, 11:39:51
  • Dernière modification le : Mardi 26 Avril 2011, 11:43:45
tous les articles de la base du CCSd...
