Malan: A Mapping Language for the Data Manipulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Arnaud Blouin
GRI
Olivier Beaudoux
GRI
Malan is a MApping LANguage that allows the generation of transformation programs by specifying a schema mapping between a source and target data schema. By working at the schema level, Malan remains independent of any transformation process; it also naturally guarantees the correctness of the transformation target relative to its schema. Moreover, by expressing schemas as UML class diagrams, Malan schema mappings can be written on top of UML modellers. This paper describes the overall approach by focusing on the Malan language itself, and its use within a transformation process.
BLO08.pdf (357.72 Ko) Télécharger le fichier
hal-00470261 , version 1 (05-04-2010)
Arnaud Blouin, Olivier Beaudoux, S. Loiseau. Malan: A Mapping Language for the Data Manipulation. ACM symposium on Document engineering, Sep 2008, Sao Paulo, Brazil. pp.66--75, ⟨10.1145/1410140.1410153⟩. ⟨hal-00470261⟩
174 Consultations
208 Téléchargements
