Grammatical inference by specialization as a state splitting strategy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
We exhibit connexions beteween two already known learning algorithms developped in different backgrounds. This allows to show that learning classical (or AB) categorial grammars by specialization can be identified with a “state splitting” strategy, in a search space made of extended automata. It also leads to a new interpretation of why it is possible to learn categorial grammars from semantically typed (in Montague's sense) examples.
Amster16.pdf (58.17 Ko) Télécharger le fichier
hal-00470267 , version 1 (05-04-2010)
  • HAL Id : hal-00470267 , version 1
Isabelle Tellier. Grammatical inference by specialization as a state splitting strategy. Amsterdam colloquium, 2007, Netherlands. pp.223-228. ⟨hal-00470267⟩
62 Consultations
50 Téléchargements
