hal-00483617, version 1
Short paper : Role of force-cues in path following of 3D trajectories in Virtual Reality.
Jérémy Bluteau 1, 2, 3Edouard Gentaz
3Yohan Payan
1Sabine Coquillart 2
15th Eurographics Symposium on Virtual Environments, 19th International Conference on Artificial Reality and Telexistence & 6th EuroVR (INTUITION) Conference. (2009) 9-12
Résumé : This paper examines the effect of adding haptic force cues (simulated inertia, compensation of gravity) during 3D-path following in large immersive virtual reality environments. Thirty-four participants were asked to follow a 3D ring-on-wire trajectory. The experiment consisted of one pre-test/control bloc of twelve trials with no haptic feedback; followed by three randomized blocs of twelve trials, where force feedbacks differed. Two levels of inertia were proposed and one level compensating the effect of gravity (No-gravity). In all blocks, participants received a real time visual warning feedback (color change), related to their spatial performance. Contrariwise to several psychophysics studies, haptic force cues did not significantly change the task performance in terms of time completion or spatial distance error. The participants however significantly reduced the time passed in the visual warning zone in the presence of haptic cues. Taken together, these results are discussed from a psychophysics and multi-sensory integration point of view.
- 1 : Techniques de l'Ingénierie Médicale et de la Complexité (TIMC)
- CNRS : UMR5525 – Université Joseph Fourier - Grenoble I
- 2 : I3D (INRIA Grenoble Rhône-Alpes / LIG Laboratoire d'Informatique de Grenoble)
- INRIA – Institut polytechnique de Grenoble (Grenoble INP) – Université Joseph Fourier - Grenoble I – Université Pierre-Mendès-France - Grenoble II – CNRS : UMR5217
- 3 : Laboratoire de psychologie et neurocognition (LPNC)
- CNRS : UMR5105 – Université Pierre-Mendès-France - Grenoble II – Université Joseph Fourier - Grenoble I – Université de Savoie
- Domaine : Sciences de l'ingénieur/Mécanique/Biomécanique
Physique/Mécanique/Biomécanique
Sciences cognitives/Neurosciences - Mots-clés : trajectory following
- hal-00483617, version 1
- http://hal.archives-ouvertes.fr/hal-00483617
- oai:hal.archives-ouvertes.fr:hal-00483617
- Contributeur : Yohan Payan
- Soumis le : Lundi 17 Mai 2010, 18:34:11
- Dernière modification le : Mardi 18 Mai 2010, 07:57:23
Documents associés
Exporter
