s'authentifier
version française rss feed
hal-00484853, version 1
Fast Resolution of Hierarchized Inverse Kinematics with Inequality Constraints
Adrien Escande 1, Nicolas Mansard () 2, Pierre-Brice Wieber () 34
IEEE International Conference on Robotics and Automation (2010) 7p.
Résumé : Classically, the inverse kinematics is performed by computing the singular value decomposition of the matrix to invert. This enables a very simple writing of the algorithm. However, the computation cost is high, especially when applied to complex robots and complex sets of constraints (typically around 5ms for 50 degrees of freedom -- DOF). In this paper, we propose a dedicated adaptation of quadratic programming that enables fast computations of the hierarchical inverse kinematics (around 0.1ms for 50~DOF). We then extend this algorithm to deal with unilateral constraints, obtaining sufficiently high performances for reactive control.
  • Domaine : Informatique/Robotique
  • Mots-clés : hierarchy of tasks – kinematics – redundancy – quadratic problem
  • Référence interne : Rapport LAAS n° 10175
  • hal-00484853, version 1
  • oai:hal.archives-ouvertes.fr:hal-00484853
  • Contributeur :
  • Soumis le : Mercredi 19 Mai 2010, 12:41:33
  • Dernière modification le : Lundi 21 Février 2011, 16:41:43
tous les articles de la base du CCSd...
