s'authentifier
version française rss feed
hal-00486755, version 2
Kinematic control of redundant manipulators: generalizing the task priority framework to inequality tasks
Oussama Kanoun (Auteur à contacter de préférence) 12, Florent Lamiraux () 2, Pierre-Brice Wieber () 34
IEEE Transactions on Robotics 27, 4 (2011) p. 785-792
Résumé : The redundant mechanical systems like humanoid robots are designed to fulfill multiple tasks at a time. A task, in velocity-resolved inverse kinematics, is a desired value for a function of the robot configuration that can be regulated with an Ordinary Differential Equation. When facing simultaneous tasks, the corresponding equations can be grouped in a single system, or better, sorted in priority and solved each in the solutions set of higher priority tasks. This elegant framework for hierarchical task regulation has been implemented as a sequence of Least Squares problems. Its limitation lies in the handling of inequality constraints, which are usually transformed into more restrictive equality constraints through potential fields. In this paper, we propose a new prioritized task regulation framework based on a sequence of quadratic programs (QP) that removes the limitation. At the basis of the proposed algorithm is a study of the optimal sets resulting from the sequence of QPs. The algorithm is implemented and illustrated in simulation on the humanoid robot HRP-2.
  • Collaboration : Zeuxis
  • Domaine : Informatique/Robotique
  • Mots-clés : Inverse kinematics – inequality constraints – task priority – hierarchy – redundancy – control – humanoid robot
  • Référence interne : Rapport LAAS n° 11363
  • Commentaire : 9 pages
  • Versions disponibles :  v1 (26-05-2010) v2 (01-06-2011)
  • hal-00486755, version 2
  • oai:hal.archives-ouvertes.fr:hal-00486755
  • Contributeur :
  • Soumis le : Mercredi 1 Juin 2011, 07:39:45
  • Dernière modification le : Mardi 13 Septembre 2011, 14:25:34
tous les articles de la base du CCSd...
