Nonlinear functional regression: a functional RKHS approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hachem Kadri
Emmanuel Duflos
  • Fonction : Auteur
  • PersonId : 844358
Manuel Davy
  • Fonction : Auteur
  • PersonId : 838036
This paper deals with functional regression, in which the input attributes as well as the response are functions. To deal with this problem, we develop a functional reproducing kernel Hilbert space approach; here, a kernel is an operator acting on a function and yielding a function. We demonstrate basic properties of these functional RKHS, as well as a representer theorem for this setting; we investigate the construction of kernels; we provide some experimental insight.
HK_AISTATS2010.pdf (639.85 Ko) Télécharger le fichier
hal-00510411 , version 1 (18-08-2010)
  • HAL Id : hal-00510411 , version 1
Hachem Kadri, Emmanuel Duflos, Philippe Preux, Stephane Canu, Manuel Davy. Nonlinear functional regression: a functional RKHS approach. Thirteenth International Conference on Artificial Intelligence and Statistics (AISTATS'10), 2010, Italy. pp.374-380. ⟨hal-00510411⟩
298 Consultations
351 Téléchargements
