On the inverse image of pattern classes under bubble sort - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Combinatorics Année : 2011
Let B be the operation of re-ordering a sequence by one pass of bubble sort. We completely answer the question of when the inverse image of a principal pattern class under B is a pattern class.
hal-00525425 , version 1 (11-10-2010)
Michael H. Albert, M. D. Atkinson, Mathilde Bouvel, Anders Claesson, Mark Dukes. On the inverse image of pattern classes under bubble sort. Journal of Combinatorics, 2011, 2 (2), pp.231-244. ⟨hal-00525425⟩
Collections
CNRS LIAFA
67 Consultations
0 Téléchargements
