Performance Evaluation and Design Tradeoffs of On-Chip Interconnect Architectures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2010
Network-on-Chip (NoC) has been proposed as an alternative to bus-based schemes to achieve high performance and scalability in System-on-Chip (SoC) design. Performance analysis and evaluation of on-chip interconnect architectures are widely based on simulations, which become computationally expensive, especially for large-scale NoCs. In this paper, a Network Calculusbased methodology is presented to analyze and evaluate the performance and cost metrics, such as latency and energy consumption. The 2D Mesh, Spidergong and WK-recursive on-chip interconnect architectures are analyzed using this methodology and results are compared with those produced using simulations. The values obtained by simulations and by analysis show similar trends in the same order of magnitude. Furthermore, WK outperforms the other on-chip interconnects in all considered metrics
bakhouya.pdf (616.76 Ko) Télécharger le fichier
hal-00534521 , version 1 (09-11-2010)
  • HAL Id : hal-00534521 , version 1
Mohmed Bakhouya, Suboh Suboh, Jaafar Gaber, Tarek El-Ghazawi, Smail Niar. Performance Evaluation and Design Tradeoffs of On-Chip Interconnect Architectures. 2010. ⟨hal-00534521⟩
234 Consultations
853 Téléchargements
