Hal-00536710, version 1
Connections between Theta-Graphs, Delaunay Triangulations, and Orthogonal Surfaces
Nicolas Bonichon
1, 2Cyril Gavoille
1, 2, 3Nicolas Hanusse
1, 2David Ilcinkas
1, 2
WG 2010 6410 (2010) 266--278
Résumé : $\Theta_k$-graphs are geometric graphs that appear in the context of graph navigation. The shortest-path metric of these graphs is known to approximate the Euclidean complete graph up to a factor depending on the cone number $k$ and the dimension of the space. TD-Delaunay graphs, a.k.a.~triangular-distance Delaunay triangulations, introduced by Chew, have been shown to be plane $2$-spanners of the 2D Euclidean complete graph, i.e., the distance in the TD-Delaunay graph between any two points is no more than twice the distance in the plane. Orthogonal surfaces are geometric objects defined from independent sets of points of the Euclidean space. Orthogonal surfaces are well studied in combinatorics (orders, integer programming) and in algebra. From orthogonal surfaces, geometric graphs, called geodesic embeddings can be built. In this paper, we introduce a specific subgraph of the $\TG$-graph defined in the 2D Euclidean space, namely the $\DTG$-graph, composed of the even-cone edges of the $\TG$-graph. Our main contribution is to show that these graphs are exactly the TD-Delaunay graphs, and are strongly connected to the geodesic embeddings of orthogonal surfaces of coplanar points in the 3D Euclidean space. Using these new bridges between these three fields, we establish: \begin{itemize} \item Every $\TG$-graph is the union of two spanning TD-Delaunay graphs. In particular, $\TG$-graphs are $2$-spanners of the Euclidean graph, and the bound of~$2$ on the stretch factor is the best possible. It was not known that $\Theta_6$-graphs are $t$-spanners for some constant $t$, and $\Theta_7$-graphs were only known to be $t$-spanners for $t \approx 7.562$. \item Every plane triangulation is TD-Delaunay realizable, i.e., every combinatorial plane graph for which all its interior faces are triangles is the TD-Delaunay graph of some point set in the plane. Such realizability property does not hold for classical Delaunay triangulations. \end{itemize}
- 1 : CEPAGE (INRIA Bordeaux - Sud-Ouest)
- INRIA – CNRS : UMR5800 – Université Sciences et Technologies - Bordeaux I – École Nationale Supérieure d'Électronique, Informatique et Radiocommunications de Bordeaux (ENSEIRB)
- 2 : Laboratoire Bordelais de Recherche en Informatique (LaBRI)
- CNRS : UMR5800 – Université Sciences et Technologies - Bordeaux I – École Nationale Supérieure d'Électronique, Informatique et Radiocommunications de Bordeaux (ENSEIRB) – Université Victor Segalen - Bordeaux II
- 3 : Institut Universitaire de France (IUF)
- Ministère de l'Enseignement Supérieur et de la Recherche Scientifique
- Domaine : Informatique/Géométrie algorithmique
- Mots-clés : Delaunay triangulation – Theta-graph – Orthogonal surface – Spanner – Realizability
- Hal-00536710, version 1
- http://hal.archives-ouvertes.fr/Hal-00536710
- oai:hal.archives-ouvertes.fr:Hal-00536710
- Contributeur : David Ilcinkas
- Soumis le : Mardi 16 Novembre 2010, 17:56:15
- Dernière modification le : Jeudi 18 Novembre 2010, 12:38:46
Documents associés
Exporter
