Numerical method for impulse control of Piecewise Deterministic Markov Processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2012
This paper presents a numerical method to calculate the value function for a general discounted impulse control problem for piecewise deterministic Markov processes. Our approach is based on a quantization technique for the underlying Markov chain defined by the post jump location and inter-arrival time. Convergence results are obtained and more importantly we are able to give a convergence rate of the algorithm. The paper is illustrated by a numerical example.
hal-00541413 , version 1 (30-11-2010)
Benoîte de Saporta, François Dufour. Numerical method for impulse control of Piecewise Deterministic Markov Processes. Automatica, 2012, 48, pp779-793. ⟨10.1016/j.automatica.2012.02.031⟩. ⟨hal-00541413⟩
153 Consultations
0 Téléchargements
