Automatic Mapping of Stream Programs on Multicore Architectures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Stream languages explicitly describe fork-join and pipeline parallelism, o ering a powerful programming model for general multi- core systems. This parallelism description can be exploited on hybrid architectures, eg. composed of Graphics Processing Units (GPUs) and general purpose multicore processors. In this paper, we present a novel approach to optimize stream programs for hybrid architectures composed of GPU and multicore CPUs. The ap- proach focuses on memory and communication performance bottlenecks for this kind of architecture. The initial task graph of the stream program is rst transformed so as to reduce fork-join synchronization costs. The transformation is obtained through the application of a sequence of some optimizing elementary stream restructurations enabling communication e cient mappings. Then tasks are scheduled in a software pipeline and coarsened with a coarsening level adapted to their placement (CPU of GPU). Our experiments show the importance of both the synchroniza- tion cost reduction and of the coarsening step on performance, adapting the grain of parallelism to the CPUs and to the GPU.
cpc10.pdf (278.59 Ko) Télécharger le fichier
hal-00551680 , version 1 (28-02-2013)
  • HAL Id : hal-00551680 , version 1
Pablo de Oliveira Castro, Stéphane Louise, Denis Barthou. Automatic Mapping of Stream Programs on Multicore Architectures. International Workshop on Compilers for Parallel Computers, Jul 2010, Vienna, Austria. ⟨hal-00551680⟩
216 Consultations
147 Téléchargements
