hal-00554841, version 1
Highly precise micropositioning task using a direct visual servoing scheme.
Brahim Tamadazte
1Guillaume Duceux 1Nadine Le Fort-Piat
1Eric Marchand
2
IEEE internatioanal Conference on Robotics and Automation, ICRA'11. sur CD ROM (2011) 5689-5694
Résumé : This paper demonstrates a precise micropositioning scheme based on a direct visual servoing process. This technique uses only the pure image signal (photometric information) to design the control law. With respect to traditional visual servoing approaches that use geometric visual features (points, lines, ...), the visual features used in the control law is nothing but the pixel luminance. The proposed approach was tested in term of precision and robustness in several experimental conditions. The obtained results have demonstrated a good behavior of the control law and very good positioning precision. The obtained precisions are 89 nanometers, 14 nanometers, and 0.001 degrees in the x, y and axes of positioning platform, respectively.
- 1 : Franche-Comté Électronique Mécanique, Thermique et Optique - Sciences et Technologies (FEMTO-ST)
- CNRS : UMR6174 – Université de Franche-Comté – Université de Technologie de Belfort-Montbeliard – Ecole Nationale Supérieure de Mécanique et des Microtechniques
- 2 : LAGADIC (INRIA - IRISA)
- CNRS : UMR6074 – INRIA – Université de Rennes 1
- Domaine : Sciences de l'ingénieur/Micro et nanotechnologies/Microélectronique
- hal-00554841, version 1
- http://hal.archives-ouvertes.fr/hal-00554841
- oai:hal.archives-ouvertes.fr:hal-00554841
- Contributeur : Martine Azema
- Soumis le : Mardi 11 Janvier 2011, 15:12:04
- Dernière modification le : Jeudi 26 Avril 2012, 10:25:06
Documents associés
Exporter
