BeeEye: A Framework for Constructing Architectural Views - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We believe that offering means for defining and building multiple architectural views of a given system enhances the understanding of the system as a whole. BeeEye is a generic and open framework for architecture reconstruction, which allows to construct architectural views using different (possibly combined) viewpoints and perspectives. The framework follows a model-driven approach where viewpoints and views (abstract and concrete) are models that are defined, constructed and used.
hal-00561196 , version 1 (31-01-2011)
Hervé Verjus, Sorana Cimpan, Azadeh Razavizadeh, Sté́phane Ducasse. BeeEye: A Framework for Constructing Architectural Views. 4th European Conference on Software Architecture, ECSA 2010, Aug 2010, Copenhagen, Denmark. pp.376-383, ⟨10.1007/978-3-642-15114-9_31⟩. ⟨hal-00561196⟩
161 Consultations
0 Téléchargements
