Simple Lyapunov Sampling for Event-Driven Control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, a simple Lyapunov sampling is proposed. Contrary to a periodic fashion which samples the system uniformly in time, an event-based scheme updates the control signal only when the system trajectory sufficiently changes. Furthermore, the present triggering mechanism is based on a Lyapunov function in order to enforce the events only when required from a stability point of view. Nevertheless, whereas the Lyapunov sampling mechanism initially introduced in Velasco et al. (2009) requires to execute a computationally heavy off-line algorithm, a fully on-line version is developed in this paper. The different approaches are tested (in simulation and practice) to show the efficiency of such an event-based control and, eventually, the performance remains ensured even if the constraint on the stability is relaxed.
IFAC09.pdf (778.15 Ko) Télécharger le fichier
hal-00568102 , version 1 (23-09-2014)
hal-00568102 , version 2 (25-05-2017)
  • HAL Id : hal-00568102 , version 2
Sylvain Durand, Nicolas Marchand, Jose Fermi Guerrero Castellanos. Simple Lyapunov Sampling for Event-Driven Control. IFAC WC 2011 - 18th IFAC World Congress, Aug 2011, Milan, Italy. 7 p. ⟨hal-00568102v2⟩
534 Consultations
265 Téléchargements
