An alternative to Dirichlet-to-Neumann maps for waveguides - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Comptes rendus de l'Académie des sciences. Série I, Mathématique Année : 2011
We are interested by the treatment of the radiation condition at infinity for the numerical solution of a problem set in an unbounded waveguide. We propose an alternative to the classical approach involving a modal expression of Dirichlet-to-Neumann (DtN) operators. This method is particularly simple to implement since it only requires the solution of boundary value problems with local boundary conditions. The corresponding approximate solution is comparable in accuracy to the one obtained by truncating the infinite series in the DtN maps.
preprint_v2.pdf (254.94 Ko) Télécharger le fichier
hal-00585361 , version 1 (12-04-2011)
hal-00585361 , version 2 (31-05-2011)
Anne-Sophie Bonnet-Ben Dhia, Guillaume Legendre. An alternative to Dirichlet-to-Neumann maps for waveguides. Comptes rendus de l'Académie des sciences. Série I, Mathématique, 2011, 349 (17-18), pp.1005-1009. ⟨10.1016/j.crma.2011.08.006⟩. ⟨hal-00585361v2⟩
255 Consultations
301 Téléchargements
