Commande Vision/Force de robots parallèles.
In this paper, force and position control of parallel kinematic machines is discussed. Cartesian space computed torque control is applied to achieve force and position servoing directly in the task space within a sensor based control architecture. The originality of the approach resides in the use of a vision system as an exteroceptive pose measurement of a parallel machine tool for force control purposes.
