Classification-based Policy Iteration with a Critic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2011
Victor Gabillon
  • Fonction : Auteur
  • PersonId : 900485
Alessandro Lazaric
Mohammad Ghavamzadeh
  • Fonction : Auteur
  • PersonId : 868946
Bruno Scherrer
In this paper, we study the effect of adding a value function approximation component (critic) to rollout classification-based policy iteration (RCPI) algorithms. The idea is to use the critic to approximate the return after we truncate the rollout trajectories. This allows us to control the bias and variance of the rollout estimates of the action-value function. %that are strongly related to the length of the rollout trajectories. Therefore, the introduction of a critic can improve the accuracy of the rollout estimates, and as a result, enhance the performance of the RCPI algorithm. We present a new RCPI algorithm, called {\em direct policy iteration with critic} (DPI-Critic), and provide its finite-sample analysis when the critic is based on LSTD and BRM methods. We empirically evaluate the performance of DPI-Critic and compare it with DPI and LSPI in two benchmark reinforcement learning problems.
Autres [stat.ML]
dpi-critic-techReport.pdf (286.61 Ko) Télécharger le fichier
hal-00590972 , version 1 (05-05-2011)
  • HAL Id : hal-00590972 , version 1
Victor Gabillon, Alessandro Lazaric, Mohammad Ghavamzadeh, Bruno Scherrer. Classification-based Policy Iteration with a Critic. 2011. ⟨hal-00590972⟩
322 Consultations
326 Téléchargements
