On the Regularity Property of Differential Polynomials Modulo Regular Differential Chains - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper provides an algorithm which computes the normal form of a rational differential fraction modulo a regular differential chain if, and only if, this normal form exists. A regularity test for polynomials modulo regular chains is revisited in the nondifferential setting and lifted to differential algebra. A new characterization of regular chains is provided.
BoulierLemaireSedoglavic.pdf (157.91 Ko) Télécharger le fichier
hal-00599440 , version 1 (09-06-2011)
  • HAL Id : hal-00599440 , version 1
François Boulier, François Lemaire, Alexandre Sedoglavic. On the Regularity Property of Differential Polynomials Modulo Regular Differential Chains. Computer Algebra in Scientific Computings, Sep 2011, Kassel, Germany. pp.1-12. ⟨hal-00599440⟩
269 Consultations
344 Téléchargements
