s'authentifier
version française rss feed
hal-00628651, version 2
A new model for shallow viscoelastic fluids
François Bouchut (, http://perso-math.univ-mlv.fr/users/bouchut.francois/) 1, Sébastien Boyaval () 23
Mathematical Models and Methods in Applied Sciences 23, 8 (2013) 1479-1526
Résumé : We propose a new reduced model for gravity-driven free-surface flows of shallow elastic fluids. It is obtained by an asymptotic expansion of the upper-convected Maxwell model for elastic fluids. The viscosity is assumed small (of order epsilon, the aspect ratio of the thin layer of fluid), but the relaxation time is kept finite. Additionally to the classical layer depth and velocity in shallow models, our system describes also the evolution of two scalar stresses. It has an intrinsic energy equation. The mathematical properties of the model are established, an important feature being the non-convexity of the physically relevant energy with respect to conservative variables, but the convexity with respect to the physically relevant pseudo-conservative variables. Numerical illustrations are given, based on a suitable well-balanced finite-volume discretization involving an approximate Riemann solver.
  • Domaine : Mathématiques/Analyse numérique
    Physique/Mécanique/Mécanique des fluides
    Sciences de l'ingénieur/Mécanique/Mécanique des fluides
    Mathématiques/Equations aux dérivées partielles
  • Mots-clés : Viscoelastic fluids – Maxwell model – Oldroyd model – Saint Venant equations – shallow-water model – pseudo-conservative hyperbolic system of equations – well-balanced finite-volume scheme
  • Commentaire : Part of this work was completed while Sebastien Boyaval was an academic host at MATHICSE- ASN chair (EPFL). SB would like to thank Prof. Marco Picasso and Prof. Jacques Rappaz for this invitation.
  • Versions disponibles :  v1 (04-10-2011) v2 (09-08-2012)
  • hal-00628651, version 2
  • oai:hal-enpc.archives-ouvertes.fr:hal-00628651
  • Contributeur :
  • Soumis le : Mercredi 8 Août 2012, 23:16:57
  • Dernière modification le : Mercredi 12 Juin 2013, 17:38:21
tous les articles de la base du CCSd...
