Multi-Bandit Best Arm Identification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2011
Victor Gabillon
  • Fonction : Auteur
  • PersonId : 900485
Mohammad Ghavamzadeh
  • Fonction : Auteur
  • PersonId : 868946
Alessandro Lazaric
We study the problem of identifying the best arm in each of the bandits in a multi-bandit multi-armed setting. We first propose an algorithm called Gap-based Exploration (GapE) that focuses on the arms whose mean is close to the mean of the best arm in the same bandit (i.e., small gap). We then introduce an algorithm, called GapE-V, which takes into account the variance of the arms in addition to their gap. We prove an upper-bound on the probability of error for both algorithms. Since GapE and GapE-V need to tune an exploration parameter that depends on the complexity of the problem, which is often unknown in advance, we also introduce variation of these algorithms that estimates this complexity online. Finally, we evaluate the performance of these algorithms and compare them to other allocation strategies on a number of synthetic problems.
Informatique
multi-bandit_techreport.pdf (279.09 Ko) Télécharger le fichier
hal-00632523 , version 1 (14-10-2011)
hal-00632523 , version 2 (25-10-2011)
hal-00632523 , version 3 (19-11-2011)
  • HAL Id : hal-00632523 , version 3
Victor Gabillon, Mohammad Ghavamzadeh, Alessandro Lazaric, Sébastien Bubeck. Multi-Bandit Best Arm Identification. 2011. ⟨hal-00632523v3⟩
297 Consultations
163 Téléchargements
