Computation of the Euclidean minimum of algebraic number fields - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics of Computation Année : 2014
We present an algorithm to compute the Euclidean minimum of an algebraic number field, which is a generalization of the algorithm restricted to the totally real case described by Cerri. With a practical implementation, we obtain unknown values of the Euclidean minima of algebraic number fields of degree up to 8 in any signature, especially for cyclotomic fields, and many new examples of norm-Euclidean or non-norm-Euclidean algebraic number fields. We also prove a result of independant interest concerning real quadratic fields whose Euclidean minimum is equal to 1.
article_algo_hal.pdf (426.02 Ko) Télécharger le fichier
hal-00632997 , version 1 (17-10-2011)
hal-00632997 , version 2 (02-10-2012)
Pierre Lezowski. Computation of the Euclidean minimum of algebraic number fields. Mathematics of Computation, 2014, 83, pp.1397-1426. ⟨10.1090/S0025-5718-2013-02746-9⟩. ⟨hal-00632997v2⟩
409 Consultations
737 Téléchargements
