Some sufficient conditions on an arbitrary class of stochastic processes for the existence of a predictor. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Daniil Ryabko
  • Fonction : Auteur
  • PersonId : 848126
We consider the problem of sequence prediction in a probabilistic setting. Let there be given a class C of stochastic processes (probability measures on the set of one-way infinite sequences). We are interested in the question of what are the conditions on C under which there exists a predictor (also a stochastic process) for which the predicted probabilities converge to the correct ones if any of the processes in C is chosen to generate the data. We find some sufficient conditions on C under which such a predictor exists. Some of the conditions are asymptotic in nature, while others are based on the local (truncated to first observations) behaviour of the processes. The conditions lead to constructions of the predictors. In some cases we also obtain rates of convergence that are optimal up to an additive logarithmic term.
pq_.pdf (119.61 Ko) Télécharger le fichier
inria-00347706 , version 1 (16-12-2008)
Daniil Ryabko. Some sufficient conditions on an arbitrary class of stochastic processes for the existence of a predictor.. 19th International Conference on Algorithmic Learning Theory, ALT 2008, Oct 2008, Budapest, Hungary. pp.169-182, ⟨10.1007/978-3-540-87987-9_17⟩. ⟨inria-00347706⟩
208 Consultations
128 Téléchargements
