A Parallel Bi-objective Hybrid Metaheuristic for Energy-aware Scheduling for Cloud Computing Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Parallel and Distributed Computing Année : 2011
In this paper, we investigate the problem of scheduling precedence-constrained parallel applications on heterogeneous computing systems (HCSs) like cloud computing infrastructures. This kind of applications was studied and used in many research works. Most of these works propose algorithms to minimize the completion time (makespan) without paying much attention to energy consumption. We propose a new parallel bi-objective hybrid genetic algorithm that takes into account, not only makespan, but also energy consumption. We particularly focus on the island parallel model and the multi-start parallel model. Our new method is based on dynamic voltage scaling (DVS) to minimize energy consumption. In terms of energy consumption, the obtained results show that our approach outperforms previous scheduling methods by a significant margin. In terms of completion time, the obtained schedules are also shorter than those of other algorithms. Furthermore, our study demonstrates the potential of DVS.
YJPDC_2884_paper.pdf (296.9 Ko) Télécharger le fichier
hal-00639966 , version 1 (10-11-2011)
Mohand Mezmaz, Nouredine Melab, Yacine Kessaci, Young Choon Lee, El-Ghazali Talbi, et al.. A Parallel Bi-objective Hybrid Metaheuristic for Energy-aware Scheduling for Cloud Computing Systems. Journal of Parallel and Distributed Computing, 2011, 71 (11), pp.1497-1508. ⟨10.1016/j.jpdc.2011.04.007⟩. ⟨hal-00639966⟩
354 Consultations
1738 Téléchargements
