Using a Cocontraction Ratio to Predict Antagonistic Behavior During Elbow Motion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Inverse dynamics methods for muscle forces prediction are globally unable to predict antagonistic activity during a joint motion. This is due to a lack of physiological information describing how forces are shared between flexors and extensors. The aim of this study is the definition and the use of a new EMG-based cocontraction ratio in an inverse dynamics muscle forces prediction approach applied to the elbow flexion motion. Results show the relevance of the ratio.
PontonnieretalISB2011.pdf (339.14 Ko) Télécharger le fichier
hal-00640207 , version 1 (14-12-2012)
Charles Pontonnier, Georges Dumont. Using a Cocontraction Ratio to Predict Antagonistic Behavior During Elbow Motion. International Society of Biomechanics 2011 Congress, Jul 2011, Brussels, Belgium. ⟨hal-00640207⟩
418 Consultations
223 Téléchargements
