A stochastic maximum principle for a stochastic differential game of a mean-field type - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
John J. A. Hosking
  • Fonction : Auteur
  • PersonId : 913868
We construct a stochastic maximum principle (SMP) which provides necessary conditions for the existence of Nash equilibria in a certain form of N-agent stochastic differential game (SDG) of a mean-field type. The information structure considered for the SDG is of a possible asymmetric and partial type. To prove our SMP we use a spike-variation approach with adjoint representation techniques, analogous to that of S. Peng in the optimal stochastic control context. In our proof we apply adjoint representation procedures at three points. The first-order adjoint processes are defined as solutions to certain mean-field backward stochastic differential equations, and second-order adjoint processes of a first type are defined as solutions to certain backward stochastic differential equations. Second-order adjoint processes of a second type are defined as solutions of backward stochastic equations of a type that we introduce in this paper, and which we term conditional mean-field backward stochastic differential equations. From the resulting representations, we show that the terms relating to these second-order adjoint processes of the second type are of an order such that they do not appear in our final SMP equations.
A_stochastic_maximum_principle_for_a_stochastic_differential_game_of_a_mean-field_type_by_John_J._A._Hosking.pdf (417.57 Ko) Télécharger le fichier
hal-00641090 , version 1 (14-11-2011)
hal-00641090 , version 2 (15-11-2011)
  • HAL Id : hal-00641090 , version 2
John J. A. Hosking. A stochastic maximum principle for a stochastic differential game of a mean-field type. 2011. ⟨hal-00641090v2⟩
194 Consultations
530 Téléchargements
