Robust RANSAC-based blood vessel segmentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Many vascular clinical applications require a vessel segmentation process that is able to both extract the centerline and the surface of the blood vessels. However, noise and topology issues (such as kissing vessels) prevent existing algorithms from being able to easily retrieve such a complex system as the brain vasculature. We propose here a new blood vessel tracking algorithm that 1) detect the vessel centerline; 2) provide a local radius estimate; and 3) extracts a dense set of points at the blood vessel surface. This algorithm is based on a RANSAC-based robust fitting of successive cylinders along the vessel. Our method was validated against the Multiple Hypothesis Testing (MHT) algorithm on 10 3DRA patient data of the brain vasculature. Over 30 blood vessels of various sizes were considered for each patient. Our results demonstrated a greater ability of our algorithm to track small, tortuous and touching vessels (96% success rate), compared to MHT (65% success rate). The computed centerline precision was below 1 voxel when compared to MHT. Moreover, our results were obtained with the same set of parameters for all patients and all blood vessels, except for the seed point for each vessel, also necessary for MHT. The proposed algorithm is thereafter able to extract the full intracranial vasculature with little user interaction.
spie2012.pdf (2.34 Mo) Télécharger le fichier
hal-00642003 , version 1 (12-10-2012)
Ahmed Yureidini, Erwan Kerrien, Stéphane Cotin. Robust RANSAC-based blood vessel segmentation. SPIE Medical Imaging, Feb 2012, San Diego, CA, United States. pp.8314M, ⟨10.1117/12.911670⟩. ⟨hal-00642003⟩
700 Consultations
672 Téléchargements
