Visual analysis of population scatterplots - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Evelyne Lutton
Jean Louchet
  • Fonction : Auteur
  • PersonId : 914138
Jean-Daniel Fekete
We investigate how visual analytic tools can deal with the huge amount of data produced during the run of an evolutionary algorithm. We show, on toy examples and on two real life problems, how a multidimensional data visualisation tool like ScatterDice/GraphDice can be easily used for analysing raw output data produced along the run of an evolutionary algorithm. Visual interpretation of population data is not used very often by the EA community for experimental analysis. We show here that this approach may yield additional high level information that is hardly accessible through conventional computation.
LuttonEA2011.pdf (906.03 Ko) Télécharger le fichier
hal-00642307 , version 1 (17-11-2011)
  • HAL Id : hal-00642307 , version 1
  • PRODINRA : 244233
Evelyne Lutton, Julie Foucquier, Nathalie Perrot, Jean Louchet, Jean-Daniel Fekete. Visual analysis of population scatterplots. 10th Biannual International Conference on Artificial Evolution (EA-2011), Oct 2011, Angers, France. ⟨hal-00642307⟩
286 Consultations
632 Téléchargements
