Runtime Verification of Temporal Patterns for Dynamic Reconfigurations of Components - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Dynamic reconfigurations increase the availability and the reliability of component-based systems by allowing their architectures to evolve at runtime. Recently we have proposed a temporal pattern logic, called FTPL, to characterize the correct reconfigurations of component-based systems under some temporal and architectural constraints. As component-based architectures evolve at runtime, there is a need to check these FTPL constraints on the fly, even if only a partial information is expected. Firstly, given a generic component-based model, we review FTPL from a runtime verification point of view. To this end we introduce a new four-valued logic, called RV-FTPL (Runtime Verification for FTPL), characterizing the "potential" (un)satisfiability of the architectural constraints in addition to the basic FTPL semantics. Potential true and potential false values are chosen whenever an observed behaviour has not yet lead to a violation or satisfiability of the property under consideration. Secondly, we present a prototype developed to check at runtime the satisfiability of RV-FTPL formulas when reconfiguring a Fractal component-based system. The feasability of a runtime property enforcement is also shown. It consists in supervising on the fly the reconfiguration execution against desired RV-FTPL properties. The main contributions are illustrated on the example of a HTTP server architecture.
facs2011_preproceedings_9.pdf (643.9 Ko) Télécharger le fichier
hal-00642345 , version 1 (17-11-2011)
  • HAL Id : hal-00642345 , version 1
Julien Dormoy, Olga Kouchnarenko, Arnaud Lanoix. Runtime Verification of Temporal Patterns for Dynamic Reconfigurations of Components. 8th International Symposium on Formal Aspects of Component Software - FACS 2011, Sep 2011, Oslo, Norway. ⟨hal-00642345⟩
305 Consultations
236 Téléchargements
