hal-00642569, version 1
L'activité de comparaison de représentations dans la mise au point de programmes
Le Travail Humain 51, 4 (1988) 351-362
Résumé : This article presents a case and field study on the debugging of a program that was to control an automatic machine tool installation. A programmer was observed full time for five weeks in his daily work, debugging the program written previously by a colleague. We chose to focus on a central process in debugging: the activity of comparison of pairs of representations, a reference and a target. For both, different types of representatations are constructed and compared consecutively, if necessary, before an error and/or its source are detected. These consecutive constructions and comparisons require increasingly complex information processing. Depending on the level in this progression, a diagnosis of the cause of the error is conducted to explain, in terms of program variables, the discrepancy between the observed (target) and correct (reference) system behaviour.
- 1 : PSYCHO ERGO (INRIA Rocquencourt)
- INRIA
- Domaine : Sciences cognitives/Psychologie
Sciences de l'Homme et Société/Psychologie - Mots-clés : debugging – testing – programming – observational study – field study – case study – automatic machine tool installations – construction of representations – diagnosis – mise au point de programme – conception de programme – observations de l'activité – étude de cas – étude de terrain – machine-outil automatisée – construction de représentations – diagnostic
- hal-00642569, version 1
- http://hal.inria.fr/hal-00642569
- oai:hal.inria.fr:hal-00642569
- Contributeur : Willemien Visser
- Soumis le : Vendredi 18 Novembre 2011, 12:27:11
- Dernière modification le : Mardi 29 Novembre 2011, 10:56:49
Documents associés
Exporter
